When connecting a free plan, how long is the life of this box and you can learn more about the restrictions
Good afternoon!
This tariff has no time limit. It has only the limitations indicated in the table, namely:
1. API
2. Integration with online stores, price platforms and marketplaces, processing price lists, working with suppliers
3. Parking your own domain
This feature will not be available.
24.09.2020, 15:20
«Один юрист із портфелем у руках награбує більше, ніж банда автоматників» Original comment available on version: ru
Куприян Владислав Валерьевич
Sanya, did I understand you correctly that you (as OneBox) guarantee that this tariff will work forever and as an integrator I can recommend small companies to use it?
24.09.2020, 15:37
Kupriyan Vlad Valerievich
Yes - You can recommend this tariff. If there are any changes, then there will be a mandatory notification about this (newsletter or article on the forum + in social networks).
At the moment, no changes are planned - new customers can freely use the free plan within the framework of the opportunities it provides.
24.09.2020, 15:49
