When adding a lead
when a client is defined in the add form, there is an additional contact field VIN-code of the car, which used to display information about the client's cars
Now this data is not displayed in the add form, although if you go to the client card, then this data is
and an important point - if you create an order or a lead from such a form, where the data about the car is not pulled up, then after the formation of the documents, the data from the database is deleted by the client (half the vin * code of the car)
for this reason, this additional field has been removed from the form so that the data about the client car cannot be accidentally deleted
When adding a lead when a client is defined in the add form, there is an additional contact field VIN-code of the car, which used to display information about the client's cars Now this data is not displayed in the add form, although if you go to the client card, then this data is and an important point - if you create an order or a lead from such a form, where the data about the car is not pulled up, then after the formation of the documents, the data from the database is deleted by the client (half the vin * code of the car) for this reason, this additional field has been removed from the form so that the data about the client car cannot be accidentally deleted
we are talking about any client, absolutely for all contacts such a situation and I also noticed a nuance - with an incoming call (from a well-known client) when calling the form to add from a pop-up window, the system does not pull up the client's data, but only the full name, in order to pull up all the data from the card, you need to delete the letter so that the system finds it again in database and select a client, then all data is displayed correctly if you don’t select a client but leave it like that... then after creating a lead, all data is deleted from the client’s card
[file]8718[/file]
[file]8719[/file]
[file]8720[/file]
[file]8721[/file]
Larin Dmitry wrote: we are talking about any client, absolutely for all contacts such a situation
Check now - the problem in the form of adding a process with the substitution of additional customer fields after selection has been fixed
does not work! I call the form for adding a lead manually enter the last name to search for a client in the database The system finds options choose the right one and below the Surname and First name fields, it doesn’t even substitute them already, not like additional fields about cars
does not work!
[file]8971[/file]
revised the previous screenshots, the client's full name is also not pulled up there, although in the MVP it was substituted in the fields I'm waiting for corrections on the client's additional fields, I did clear the cache if anything
Larin Dmitry wrote: I call the form for adding a lead
Provide a link where you make the addition - I'll check. Fields must be displayed in the add form
How can I make a link for you if it's a pop-up window???? click the button above - create a lead in the window that opens, enter the client's last name and then what has already been described these clients are displayed on the form for adding a Lead for testing, additional fields of the client (information about the car) are also displayed so as not to accidentally delete information about the cars during the work, I only display for the duration of the test ..
Larin Dmitry wrote: click the button above - create a lead
that's what interested me works both from the menu and from the list of leads
[file]9065[/file]
