Set up a process display page for your personal account.
But it doesn't apply to process contacts, the standard interface is shown for them.
For process clients, it shows the customized interface, and for process contacts, it shows the standard interface.
https://dai-spisat.1box.link/client/order/2324/ where the configured interface is displayed and the contact is a client of the process. on the screen showed that the configured interface is displayed [file]17657[/file]
https://dai-spisat.1box.link/client/order/2323/ process where the interface is standard. and the contact is added to the process as a process contact. on the screen showed that here is the standard interface [file]17658[/file]
Set up a process display page for your personal account. But it doesn't apply to process contacts, the standard interface is shown for them. For process clients, it shows the customized interface, and for process contacts, it shows the standard interface. https://dai-spisat.1box.link/client/order/2324/ where the configured interface is displayed and the contact is a client of the process. on the screen showed that the configured interface is displayed https://dai-spisat.1box.link/client/order/2323/ process where the interface is standard. and the contact is added to the process as a process contact. on the screen showed that here is the standard interface
Sukhanitsky Andrey OneBox CORP wrote: If you create an interface for a contact group, then it is necessary that the contact process is also in this group
Nalashtuvav for a group in the same contact and for "Without a group" Trying to see the groups, moving other groups - the result of the same. For the vicorist test, one and the same contact, in one process, the client, and in the other contact process, in both modes, shows a different interface. The contact is the same, the group is no longer important here, the interface can be the same even though the group does not change depending on the status of the inputs in the process bug here
Sukhanitsky Andrey
bug here
So, there are 2 different processes. in one process, the contact for which I logged into the account is the client and the correct interface is displayed there, and in the other contact process, the standard code 2323 is displayed there. There, just name contacts similar. one Toast another Testovy Only what, having reconsidered to another bp, seems to be correct. The problem is that the interface is the mood for the bp status. Nutrition information: Chi can you throw off the settings for the interface for the group chi bp chi status? Would you like to see a flashy interface?? Dyakuyu shto pіdshtovhnuv to the correct vіdpovіdі) For I would have been stupid for a couple more days
Sukhanitsky Andrey
OneBox CORP wrote:
Return respect [file]17682[/file] [file]17683[/file]
Andrey wrote: Chi can you throw off the settings for the interface for the group chi bp chi status? Would you like to see a flashy interface??
You can see all the blocks according to the status, you can see the standard aiuo of the one for the BP patching, in two words - chipping in
Dyakuyu, pratsyuє Is it possible for you to know, how can pardon be carried out in the client's office to stand at the stage of "Fence over the fallow watering" or "Change the fallow watering" ??? At once, write simply that Zmini is saved and not transferred to the stage.
Sukhanitsky Andrey
Dyakuyu, pratsyuє
Sukhanitsky Andrey OneBox CORP wrote: I won’t say for sure, but it seems like they can look up
I also remember that in earlier versions it was different. Thanks for the help
Sukhanitsky Andrey
Thanks for the help
