Good afternoon!
The "Pay" button in the client's personal account does not work. Integration with Privat24.
[file]12836[/file]
What could be the problem?
Good afternoon! The "Pay" button in the client's personal account does not work. Integration with Privat24.
Torbin Elena wrote: The "Pay" button in the client's personal account does not work. Integration with Privat24.
To check this - we need to go to your OneBox. But since you have blocked access for our employees, we cannot do this.
[file]13257[/file]
Another question on the topic - we have configured integration with Privat24 for a legal entity, as well as automation of "auto-client account statement" (for sole proprietorship), but to pay in your personal account, you need a merchant, that is, integration with an individual's card, and this is another account and Privat . How to add new integration with Privat24? Perhaps this is the problem... PS Access for employees is open.
[file]13257[/file]
Torbin Elena wrote: Another question on the topic - we have configured integration with Privat24 for a legal entity, as well as automation of "auto-client account statement" (for sole proprietorship), but to pay in your personal account, you need a merchant, that is, integration with an individual's card, and this is another account and Privat . How to add new integration with Privat24? Maybe this is the problem..
https://crm.hotsalon.com.ua/admin/shop/integrations/privat24-integration/control/
you can specify the merchant's data in the same integration - get them from Privat
I also tried this, but the Pay button in my account does not work( One more question - if I need to connect another integration with Privat24 for a legal entity, what should I do then?
Torbin Elena wrote: I also tried this, but the Pay button in my account does not work(
Can you link where it doesn't work?
Torbin Elena wrote: One more question - if I need to connect another integration with Privat24 for a legal entity, what should I do then?
You seem to have the ability to specify access in the payment import actions - add actions as much as you like.
1. Here, for example, the payment link does not work: https://crm.hotsalon.com.ua/client/order/52367/ 2. That is, there is one ID Client in integration, and another in automation? To clarify: we are talking about different Privat accounts, respectively, different IDs and autoclient tokens. Will it work exactly?
Button fixed But probably you do not have a working merchant, you need to clarify the essence of the error on the Privat side
Torbin Elena wrote: 2. That is, there is one ID Client in integration, and another in automation? To clarify: we are talking about different Privat accounts, respectively, different IDs and autoclient tokens. Will it work exactly?
Yes, you have the ability to set up several actions with different autoclient accesses - everything will be imported.
Button fixed
