Here is the filter https://testonebox.crm-onebox.com/admin/shop/users/contact-mode-listing/mode/?groupid=0&filtertypesex=&filternamelast=&filtername=&filternamemiddle=&filtercompany=&filterpost=&filteremail=test&filterphone=&filtercountry=&filterregion =&filterdistrict=&filtercity=&filterstreet=&filterlogin=&filtertags=&filtercomment=&filterdistribution=&filtercontractorid=&filtermanagerid=&filtercreatorid=¬ordertype=&filterlevel=&filtercdatefrom=&filtercdateto=&page=
I'm trying to filter out contacts that have "test" in the mail name, but for some reason it shows all contacts, why?
Here is the filter https://testonebox.crm-onebox.com/admin/shop/users/contact-mode-listing/mode/?gr... =&filterdistrict=&filtercity=&filterstreet=&filterlogin=&filtertags=&filtercomment=&filterdistribution=&filtercontractorid=&filtermanagerid=&filtercreatorid=¬ordertype=&filterlevel=&filtercdatefrom=&filtercdateto=&page= I'm trying to filter out contacts that have "test" in the mail name, but for some reason it shows all contacts, why?
Ustimenko Igor OneBox CTO wrote: because the search is based on the exact match of the mail and not the occurrence of the word test
1. Why did I write at the entrance to the system? Your OneBox testonebox.crm-onebox.com switched off 2. When searching for a contact by phone, if you entered part of the phone, it shows emptiness (that is, zero contacts), when entering mail, on the contrary, it shows everyone, why there is no single logic in the search for the fields that are nearby 3. Why doesn't it search by partial match (it's somehow not convenient, if we need to choose, for example, a client with the "gmail.com" domain, then it turns out that it can't be done quickly)?
Ustimenko Igor
Your OneBox
switched off
[file]3444[/file]
1. contact support I think because of your fake phone 2-3. why should it be? what stupid questions. Because you so wanted Vladislav?
Tester
Client wrote:
Ustimenko Igor
Your OneBox
switched off
[file]3444[/file]
Ustimenko Igor OneBox CTO wrote: 1. contact support I think because of your fake phone
1. And where did you get the idea that I have a fictitious phone (somehow it turned out strange that everything worked before your answer, and then stopped working)? 2. Contact the TP, do you mean write a separate ticket on the site or write in a chat or by phone?
Ustimenko Igor OneBox CTO wrote: 2-3. why should it be?
3. As for me, some kind of logic in the filters should be observed, if it filters according to the principle strictly equal in both fields, then the result should be empty in both cases or in both cases all contacts, but you have something unsystematic, in one case everything Contacts fall out, in another, nothing or I did not understand some kind of your logic? 4. Why did they search for a complete match (as for me, this only complicates the search for a contact (I made a mistake by one digit and you can no longer find a contact), there are times when customers make mistakes and enter a phone number not 093, but 063, and in this case, find a contact in base will be difficult enough)?
Ustimenko Igor
Ustimenko Igor
1-2. I think you should call me I don't manage demo systems but I think because of the phone the system automatically switched to disabled 3-4. this is purely your opinion, I don’t see the point in wasting time on a discussion
Tester Don't call
Client wrote:
Ustimenko Igor
Ustimenko Igor
