Please help with solving the problem. Unable to reset interface to default. The standard interface has 2 tabs. I'm trying to remove all interface blocks, but it doesn't help. How can I assign an interface to the contact type "Individual" interface "Default"?
Thank you.
[file]16341[/file]
Please help with solving the problem. Unable to reset interface to default. The standard interface has 2 tabs. I'm trying to remove all interface blocks, but it doesn't help. How can I assign an interface to the contact type "Individual" interface "Default"? Thank you.
Igor Ustimenko Good afternoon, Please tell me, can there be some kind of setting to reset the interface of contact types or groups to the standard one? I tried everything that I know and no one in the chat knows how to solve it.
[Igor Ustimenko #9]
Good afternoon,
The fact is that I accidentally changed interfaces for several types and groups and now I can’t return it in any way. I don't want to delete and create groups again. Hope for understanding.
This is the name of the null interface: /app/contact/usergroups/setting/0/interface/ Itself yogo needs to be done, so that you can boulo where you roll Then delete all blocks of the other interface and save Rise up for the locks of zero If you make changes to this new interface, the link from 0 is cut off, until that moment all changes to the zero interface will be broadcast on the new
Taxi seems to have figured it out. We delete all blocks - the interface is reset to the standard one, but at the same time it simply does not show that now the interface is like the standard one.
Kornev Mikhail ergo wrote: Taxi seems to have figured it out. We delete all blocks - the interface is reset to the standard one, but at the same time it simply does not show that now the interface is like the standard one.
Kornev Mikhail
Yes
here is my old video
https://youtu.be/CZuuc2N4_jA
