The amount "paid" in the parent process is not always and not always displayed on the basis of payments in subprocesses.
To do this, it was indicated on the finance settings page /admin/shop/settings/finance/ tick [file]4379[/file]
As a result, the payment is not displayed in the paid column when orders are displayed in the list
admin/customorder/zayavka/?fromfiltercustomnayakudatupotribno99=&tofiltercustomnayakudatupotribno99=&filtercustomchergabudivnitstva139=&filtercustomadresazhk83=&filtercustomklasvitrat84=&filtercustomtipvitrat85=&filtercustompidtipvitrat86=&filterauthorid=&filtercustomnazvamaterialuroboti88=&filtermanagerid=&filtername=&filternumber=&contractorsid=&filterid=&filtercdatefrom=&filtercdateto=&filterpayment=&filterpassedstatuses=1&statusid[0]=147&filterdatetofrom= &filterdatetoto=&filterdateplanfrom=&filterdateplanto=&filteremployerid[0]=&ok=1&searchLine=
fo
The amount "paid" in the parent process is not always and not always displayed on the basis of payments in subprocesses. To do this, it was indicated on the finance settings page /admin/shop/settings/finance/ tick As a result, the payment is not displayed in the paid column when orders are displayed in the list admin/customorder/zayavka/?fromfiltercustomnayakudatupotribno99=&tofiltercustomnayakudatupotribno99=&filtercustomchergabudivnitstva139=&filtercustomadresazhk83=&filtercustomklasvitrat84=&filtercustomtipvitrat85=&filtercustompidtipvitrat86=&filterauthorid=&filtercustomnazvamaterialuroboti88=&filtermanagerid=&filtername=&filternumber=&contractorsid=&filterid=&filtercdatefrom=&filtercdateto=&filterpayment=&filterpassedstatuses=1&statusid[0]=147&filterdatetofrom= &filterdatetoto=&filterdateplanfrom=&filterdateplanto=&filteremployerid[0]=&ok=1&searchLine= fo
Duboviy Bogdan wrote: for example, in ticket 10232, despite the fact that there is a payment in the subprocess And if you go into the application and create any payment in it, then after that the payment from the subprocess will be displayed in when the applications are displayed as a list. I deleted the payments
Correctly, I understand that you created payments, then indicated the setting that "when adding, recalculate the parent" and consider it an error that after that it was not recalculated for existing payments?
No, payments that were added after setting are not displayed
Duboviy Bogdan wrote: No, payments that were added after setting are not displayed
Now, with certain actions, can you make it so that when a payment is added to the child, the recalculation does not occur in the parent? If yes, please indicate the sequence of actions you perform using an example.
/admin/customorder/zayavka/9965/edit/ 1. An order for a certain amount has been created 2. This bid was created under the procurement process 3. A payment made through the autoclient was attached to the subprocess. 4. The recalculation did not occur in the parent.
[file]4502[/file]
Duboviy Bogdan wrote: 3. A payment made through the autoclient was attached to the subprocess.
how did you attach the payment? manually somewhere or did the action immediately attach?
Duboviy Bogdan wrote: manually on the page of actual payments, after the payment was created attached to the process through the process field in the payment
Through quick editing in the payment table? Or did you go directly to editing the payment?
As far as I can see, the recalculation should occur if the setting "When adding a payment to the process, recalculate the amount of payment and obligations of the parent process" is specified and the process is specified. Is there an example of an unattached payment that can be linked to some process and the recalculation will not occur (so that I can do this and check)?
