Good afternoon
I ask you to check - the "Integration of XML Products (Export)" automation action does not work, the data in XML is not updated.
Thank you!
Good afternoon I ask you to check - the "Integration of XML Products (Export)" automation action does not work, the data in XML is not updated. Thank you!
The action does not fire at the specified interval, the action has an update interval of 3 minutes, that is, by a minute cron. It also does not update forcibly, if you check the box.
