EDIT: take the LAST digits from the additional field of the process
There is an action "write value to additional field", it can cut off N characters from the end of the resulting string
need improvement so that in this action it would be possible to specify to cut off N characters FROM THE BEGINNING of the resulting string
there was an assessment https://1b.app/ru/forum/business-processes/15555-kakim-deystviem-ya-mogu-brat-po... how I would like to pay and implement client
I will explain why - and if my plan is doomed to failure, please write about it :)
if the client wants a refund - he tells the manager the card number, for example 444111 **** 481458
payment is always from a monobank, but if it is to a private card, then mono will not send a "comment" with the orderid variable. But the card in the format 444111 **** 1458 will be transferred
there is a process for returns, for example https://murmur.1b.app/87710/ in which the card to which the transfer will be indicated is indicated in the additio
Viktor Viktorovych Mazur
in the setting that is now specify a negative number. If you specify negative, then it will cut off the specified number of characters from the end. For example, if you enter -10, then it will cut off 10 characters from the end.
11.11.2022, 15:37
this
Wow, I'm so sorry ????
14.11.2022, 12:51
Мазур Віктор Вікторович
bu
Mazur Viktor Viktorovich
Unfortunately, it didn't work ((doesn't allow you to specify a negative number
procedure here: https://murmur.1b.app/app/workflow/13/procedure/65/
you can check in the process here https://murmur.1b.app/88217/
16.11.2022, 22:45
clear, then 1h and I will make the possibility of such a trick there
17.11.2022, 11:01
bu
Will the payment go to my account?
17.11.2022, 11:14
can you either send 30 bucks in the form of a donation to this message or can I invoice for the same amount, whichever is more convenient?
17.11.2022, 11:20
bu
I'll send a donation) thanks)
17.11.2022, 11:21
bu
Tell me, will it work as I described with the import of Mono payments?
17.11.2022, 11:22
you can test it yourself. Pens in the additional field write down the value and find the payment on it
17.11.2022, 11:41
bu
ok, I’ll test it and if everything is ok, then I’ll immediately pay here)
17.11.2022, 11:46
bu
doesn't work like this :(
18.11.2022, 11:08
bu
even in your scheme does not mean
yes, I’m still dealing with ) we’ll return to this issue a little later, when I figure out regular expressions :)
I know that this is not accepted, but the super-duper is waiting for the assessment of this revision, the deadlines are burning
https://1b.app/ru/forum/warehouse-management/15874-otsenit-dorabotku-poisk-seriy...
If it’s still possible to look, then tea from me :)
18.11.2022, 14:40
bu
THANKS!
19.11.2022, 15:29
