Good day. Judging from the description of the application, you can scan a barcode with your phone, for example, a consignment note, and the system will automatically open the process in which such a consignment note was found. How can this be done?
I installed the application, installed the settings I found https://prnt.sc/1rtK_kPXmDrW
What are the next steps? How do I start working with the app?
Good day. Judging from the description of the application, you can scan a barcode with your phone, for example, a consignment note, and the system will automatically open the process in which such a consignment note was found. How can this be done? I installed the application, installed the settings I found https://prnt.sc/1rtK_kPXmDrW What are the next steps? How do I start working with the app?
