Printing a barcode image for EAN-12
The CRM system uses printing of price tags with a generated barcode image. Some products have a barcode with a length of 13 characters (EAN-13), others have a length of 12 characters (EAN-12).
When generating an image for EAN-12, the system automatically adds an extra 13th digit https://monosnap.com/file/hpETSV9usXtobVfEX4JlbbDBSe7mot , which results in the barcode not being in the product database after printing and scanning.
Is there a variable in the system that allows you to correctly generate a barcode image in the EAN-12 format? If there is no such variable, evaluate the work for generating an EAN-12 image without automatically adding extra digits.
Additionally, I would like to ask you to evaluate the development of a universal variable that will automatically determine the format (EAN-12 or EAN-13) depending on the length of the barcode and generate the corresponding image, if such a solution can be implemented.
There is no EAN-12 format as such, it is UPC-A with 12 digits, rather its generation is not in the system
In EAN13, the last digit will always be formed separately when constructing the check digit, this is a check digit and is calculated according to its own principles.
Your account number is formed by 000001915457, and for the number you want to get, you need 0000001915457
Maybe if you enter it into the system yourself by scanning the barcode in the field - the first 0 is cut off. Tell me how exactly you enter this barcode?
18.06.2025, 22:29
It is not possible to change the principle of scanning and recognizing a barcode in the system, because there are different types of codes from different suppliers. We need to improve the graphic display of a variable that will display 12 if there are 12 digits and 13 if there are 13 digits in the barcode. Please evaluate the improvement of such a variable.
19.06.2025, 11:23
The question is still relevant, tell me if it is possible to improve the graphical representation of the variable, which will display 12 if there are 12 digits and 13 if there are 13 digits in the barcode, and how long this improvement will take approximately.
24.06.2025, 14:03
Good afternoon. I would like to clarify whether it is possible to implement the improvement that I described in this request?
Please advise if this is technically possible and if there is an approximate time/cost estimate if such a refinement is possible.
30.06.2025, 11:38
