Good afternoon. Please tell me how to print an already created barcode for this product in EAN-13 (not numbers, but the picture with stripes) from a product card, while specifying the dimensions of the barcode itself.
In the Documents application there are price tags /app/document/pricecode/templates/ where you can configure exactly what size and content it will be Next, send the product to Documents -> Create price tags, there will be settings that will allow you to set the desired size and orientation for printing
Thank you. Our stickers are 40x80 mm. But when choosing a size, this is what happens.
[file]22574[/file]
[file]22575[/file]
[file]22574[/file]
[file]22575[/file]
[file]22574[/file]
[file]22575[/file]
I replaced the variables with ean13svg, everything is displayed normally, but it does not fit on one page, where can you trim the height of the strips a little?
{full name}
{barcodeimageinternal13svg}
[file]22576[/file]
{full name}
[file]22576[/file]
[file]22576[/file]
[file]22576[/file]
You need to use the barcodeimageexternalean13svg variable - this variable will take the value from the barcode field on setting dimensions when printing, you can see the discussion in the topic https://1b.app/ru/forum/managing-documents-and-document-templates/18037-srochno-... pechat-ih-na-printere/ there is an example of how you can set the size for printing a price tag
on setting dimensions when printing, you can see the discussion in the topic https://1b.app/ru/forum/managing-documents-and-document-templates/18037-srochno-nuzhno-sdelat-shablon-etiketki-60h40-i-vozmozhnost- pechat-ih-na-printere/ there is an example of how you can set the size for printing a price tag
Didn't quite understand where to write this code?
[file]22577[/file]
<div style="width: 50%; height: 15px; overflow: hidden; margin: 0 auto;">
[file]22577[/file]
<img src="/media//productbarcode/product40502internal.png?1654513096" style="width: 100%;">
[file]22577[/file]
</div>
[file]22577[/file]
Here is my code on the screen.
[file]22577[/file]
[file]22577[/file]
This code change didn't help :( To change the size of the image, you can add the following code: <!DOCTYPE html> <html> <head> <style type="text/css"> img { width: 140%; height: 10%; align: center; } </style> </head> at the beginning of the code, replacing your tags with these. And with the width and height parameters, you change the number of percentages.
<!DOCTYPE html>
<html>
<head>
img {
width: 140%;
height: 10%;
align: center;
</style>
</head>
