Please change the color of the notification when adding an item using a barcode is unsuccessful in the Re-listing section to red. Ideally, add error text as well.
[file]22405[/file]
[file]22406[/file]
Now the notification differs from a successful one only in the absence of text. When scanning a product in bulk, it is very easy to not notice that the product has not been added.
[file]22405[/file]
[file]22406[/file]
[file]22405[/file]
[file]22406[/file]
[file]22405[/file]
[file]22406[/file]
Rodion wrote: Please change the color of the notification when adding an item using a barcode is unsuccessful in the Re-listing section to red. Ideally, add error text as well. Now the notification differs from a successful one only in the absence of text. When scanning a product in bulk, it is very easy to not notice that the product has not been added.
Good day. Could you please show me your algorithm for repeating empty notifications about success?
Good day.
In the inventory, if you enter a non-existent barcode, you will get an error
[file]22585[/file]
https://one-box.shine-bright.com.ua/app/storage/process/stocktaking/?storagefromid=4&storageuserid=0
[file]22585[/file]
[file]22585[/file]
Rodion wrote: Can you evaluate the improvement by reproducing the sounds of successfully adding a product using a barcode and in case of an error?
a separate topic
a separate topic
