If the process https://aquadevice.crm-onebox.com/7478595/ is sent to Show operations on the process, zeros are displayed in the columns Product quantity, Product price, Product amount Screen 1: https://i.imgur.com/yk7taOB. png
https://aquadevice.crm-onebox.com/app/storage/?tabkey=journal&dumpHash=app-object-dump-f9c6f4ce67bc74a21083430317c41be8
If you go to Details there, this data is Screen 2: https://i.imgur.com/LXKB41h.png
When using the action of changing the date of a warehouse operation, the quantity and amount of the transaction are recalculated. The employee from whom the changes were made has access to changing the warehouse transaction, but does not have access to viewing the log of the required warehouse transactions. You can give access to view all journals and then when updating a warehouse transaction, the quantity/amount will be updated correctly
To update the quantity/cost of a warehouse operation, just go to “View warehouse operation” -> in the goods table, select Edit column and click Save this way the entire operation will be recalculated
