This is not the case in the Warehouse application. You can use the report "Change of balance in warehouses" You need to add a report and a filter for it, without filtering by composition, nothing will show
This is not the case in the Warehouse application. You can use the report "Change of balance in warehouses" [file]18249[/file] [file]18250[/file] [file]18251[/file]
Sukhanitsky Andrey OneBox CORP wrote: This is not the case in the Warehouse application. You can use the report "Change of balance in warehouses" You need to add a report and a filter for it, without filtering by composition, nothing will show
Thank you, but how much will it cost to transfer the Quantity and Amount functionality to a date with MVP in order to see the total balance of the warehouse for a certain time?
Sukhanitsky Andrey
Farkhshatov Rodion wrote: Thank you, but how much will it cost to transfer the Quantity and Amount functionality to a date with MVP in order to see the total balance of the warehouse for a certain time?
it will be transferred to another client within a couple of weeks
super, I hope it will work correctly, we are waiting
Ustimenko Igor
Farkhshatov Rodion wrote: super, I hope it will work correctly, we are waiting
And in what light is it in MVP?
Immediately in the Warehouses section there is a filter and a tab on top. I have on the screen above
Sukhanitsky Andrey
Farkhshatov Rodion wrote: Immediately in the Warehouses section there is a filter and a tab on top. I have on the screen above
Yes, but it doesn't work
Yes, work is incorrect in MVP
Sukhanitsky Andrey
