Refine the variable for checking products in the "Integrate XML Products (Export)" action
https://cabinet.b2bframes.com/
XML Products Integration (Export) (box_auto_action_universal_products_export_xml)
We need to improve the ability to specify a variable here
Need variable - Current date, Current date and time
That is, I will indicate the date in the additional field of the product and I need to unload only products whose date in the additional field is equal to the current one (maybe more)
OneBox Corp - Інтегратор
Let's pay by card, let's
06.07.2021, 15:19
Paid, sent receipt
07.07.2021, 16:12
Improved variables in the specified fields:
[cdate] - current date
[cdatetime] - current date and time
[cdatetime|date_format] - current date and time in the specified format (for example Ymd H:i)
08.07.2021, 11:49
gun, I'll check it out in a few hours
08.07.2021, 11:52
An important question - if the product field is not filled, how will it work?
For example, if you set the conditions
Additional field > [cdate]
or
Add. field < [cdate]
08.07.2021, 13:56
08.07.2021, 14:07
Product not included in feed
08.07.2021, 14:07
or
I think you yourself know the answer to this question. If the condition is less, then it will work, because the additional field is less.
Sukhanitsky Andrey
https://cabinet.b2bframes.com/admin/shop/products/20461/edit/#
Product not included in the feed
and should not - the condition on the date of creation does not fit.
08.07.2021, 14:57
Plugged to remove the condition by the date of creation. It works, everything is ok
08.07.2021, 15:36
