Low memory
Good day. There was 50% free memory on the SSD, I recently saw that there was quite a bit of it left.
How much does it cost to clean the memory on the SSD, and remove deleted products without damaging the image of the product?
Because if I set the automatic action to delete the deleted products, the photos are also deleted from the non-deleted products.
thank you
You can clean the logs on the server
will take up to 1 hour of work.
the script has already run so that your system has not crashed
22.07.2024, 16:38
I agree, I'm waiting for the bill.
Another question
1. How much space will be freed up
Did you run the script to delete deleted products?
22.07.2024, 16:50
58GB will be free after logs and history when it finishes cleaning
22.07.2024, 16:55
what about deleted products?
22.07.2024, 17:23
they take up little space
22.07.2024, 18:02
but can you still also delete it together with the photo, please, but so that the photo of the undeleted product is not affected?
22.07.2024, 18:09
cleaned up
23.07.2024, 10:42
there is also a media backup until the evening, if everything is ok, I will delete it, if not, I can return it
23.07.2024, 10:44
Ustimenko Igor
The photos were also deleted. Return please
23.07.2024, 12:36
