Template variables not working
https://kyivcityroast.1b.app/app/templatecomment/
Good afternoon,
First, the "email templates" application does not work in processes and there is no option to select an email template
Second, I added a letter as an SMS template, but it also does not work correctly, I tried different variables. not one worked and did not give a result.
Tell me how to use email templates so that values from the process are substituted?
variables work when they are written in the action "Send a message by email"
you need to choose to whom to send, the type, the content of the letter itself https://bit.ly/3TVjbvm (the last pointer on the screen is a complete list of variables that can be inserted into the letter)
30.03.2023, 23:29
Анатолий
Интегратор
Ihor Susiak
Do you want to say that there are 2 applications, but neither one works as letter templates? To choose a template, substitute variables, did you edit the text, add an attachment and send the CP?
31.03.2023, 00:11
Valeria,
checked separately on the OS - the variables are substituted even if you send the letter manually, but it must be sent from the process so that there is somewhere to substitute the data.
31.03.2023, 11:48
Ihor Susiak
Valeria,
I checked, it came to the mail with falsified data, thanks. But it is necessary that the data were substituted immediately upon opening. And the managers could check whether they had filled everything, and to fill it before it left the client. How much time can this modification take?
06.04.2023, 20:57
Valeria
Consulting company "Sales Bureau" wrote:
Ihor Susiak
Valeria,
I think it is possible to substitute in live in 3 hours
12.04.2023, 23:38
