Good afternoon, we have installed automation for translating Commodity Names, Categories and Filters. Ale pressed є more rich filters without translation. How can you correct this situation?
Screen fit
[file]17438[/file]
Good afternoon, we have installed automation for translating Commodity Names, Categories and Filters. Ale pressed є more rich filters without translation. How can you correct this situation? Screen fit
1. you showed your token on the screen - what is not safe - now you can do it ) 2. I didn’t translate links to products, but I need to translate up to 50 products per year
Good day, dear - replacing the token)))
So 50 goods for a year, ale day it was completed more than a month, and for the whole hour I think it’s not enough to take the translation =)
There are a lot of such goods, mayzhe in the skin є not translated filters and their meanings:
1. https://owwa.crm-onebox.com/app/product/31995/edit/
2. https://owwa.crm-onebox.com/app/product/40122/edit/
3. https://owwa.crm-onebox.com/app/product/41381/edit/
4. https://owwa.crm-onebox.com/app/product/41375/edit/
5. https://owwa.crm-onebox.com/app/product/32493/edit/
Good afternoon. Unfortunately, you have too many filter values, namely 258885, of which about 20k are unique. It will take 5177 cron launches to translate all of them. If you translate only unique ones, then you need to partially rewrite the action. You can also remove it so that it does not translate numbers, for example, but only the value where there are letters. To do all this, you need about 2 hours of refinement. Then, after completing it and setting a limit of approximately 100-200 for 2 days, you will have all the translations for filters.
