Improvements to the action "Translate product fields to the specified language"
Hello! There is an action "Translate product fields to the specified language".
It is necessary to be able to specify additional product fields that need to be translated.
It is also necessary to provide fields in which to write the translation in the case of additional fields.
Please rate.
And another question, does this action work in the OS? Because we failed to launch it.
Good afternoon. Yes, on os this action is called the same.
It is possible to make settings for the fields where you will choose
Field 1 - Field 2
Field 3 - Field 4
where fields 1 and 3 are where to get the values, fields 2 and 4 - where to write them. It will take 4 hours of revision. If you did not manage to find an action on os - drop the link to the box, I will try to help you
11.08.2022, 18:20
thank you for the rating.
we found the action in the OS, but the translation does not take place. and in the MVP version it works only for two products. therefore, it is important to understand what the limitations are.
11.08.2022, 20:20
