Processes for automatic action were not created
Hello.
There is an action "to generate BP on groups" in the set days and time.
Processes were not generated for the entire group. Example for contacts where BPs were created correctly: https://om24.1b.app/app/contact/1462/ and https://om24.1b.app/app/contact/1472/
An example where processes in a given group were not created at a given time: https://om24.1b.app/app/contact/1242/
What could be the reason?
Original question is available on version: ru Інтегратор CRM+ERP. Компания Olmonic
Olmonic
Інтегратор OneBox
Processes were created only when the checkbox "Create processes every day" was checked. It was created for the entire specified group, and on the scheduled day, the processes were created randomly. Tell me what could be the reason?
01.07.2022, 11:28
Інтегратор CRM+ERP. Компания Olmonic Original comment available on version: ru
Olmonic
Інтегратор OneBox
The question is relevant
04.07.2022, 16:00
Good afternoon. Action only runs on the 7th
15.07.2022, 15:30
Olmonic
Інтегратор OneBox
anonymous hamster
Yes, but also if the checkbox "Create processes every day" is checked. That is why, with such conditions, processes are created on a given day and time
15.07.2022, 15:42
Morozova Olesya
Olmonic - FOP MOROZOVA O.P.
the action does not run on any other day than the 7th of each month with these settings. Perhaps you have a task repetition action in your bp and this is why new orders are created or something else.
15.07.2022, 15:59
Olmonic
Інтегратор OneBox
anonymous hamster
Morozova Olesya
I'll describe how the setup was:
On a given day and at a given time, the action "generate BP by contact groups" was set
The first processes were created for the given group. Then the given date came and the processes were created randomly by group. Regardless of the status of the process, etc.
Those. out of 264, only 36 new ones were created.
During subsequent test runs, the above situation occurred.
And only when the checkbox in this action "Create processes every day" was checked, the creation of processes was generated correctly on the specified day and time.
Tested on several boxes.
It's just that if Boxing is on the "for data" tariff, it is this checkbox "create processes every day" that is misleading.
Maybe, as an option, add "Create processes every day and at the specified date and time"?
15.07.2022, 16:26
Morozova Olesya
because boxing looked that it had already created a task for the user this month and did not create a new one. And when you turn on the checkbox, he looks today whether he created one or not.
If you need new tasks every day, remove the selected date and everything will be ok
15.07.2022, 16:52
Olmonic
Інтегратор OneBox
anonymous hamster
Morozova Olesya
I did not specify in the previous comment that the given date was in the new month.
And on it, processes were created randomly for a group of clients.
New tasks are not needed every day.
Processes are created on a given date for the entire selected group of clients with the "create every day" checkbox enabled. Xs why so, but it worked when testing on 2 different Boxes)))
15.07.2022, 17:42
every task has a key
issue-group-IDUSER-IDGROUPIDBusinessProcess
if you check the box, the current date is added to it.
In the first case, the action finds the old tasks that you have already created in this bp for this user for this group. And when you turn on the checkbox, it does not find such processes and creates new ones.
So, what do you need from me?
15.07.2022, 17:56
