Process not created from email
Setting "Allow adding a user without contact details" Enabled
14.06.2022, 10:11
Today a new leaf has arrived, but the process has not happened
14.06.2022, 11:03
Пятецкий Николай Николаевич
Insiders - OneBox
Hello! According to our practice, this is most likely due to some actions at the initial stages. Or, for example, there is no process name. In general, there are many options. We recommend that you try the following. Add a start stage, for example, with the name "New letter" and set two actions there. The first is "Set stage due date" and "Switch stage when stage expires". Set in the first action literally 1 minute. And, accordingly, set the creation of the process from this status in automation. It helps 70% of the time
If not, you need to look in more detail. If interested, we can provide our services and help deal with the issue.
14.06.2022, 17:47
