On the example of the process https://crm.ohrana.ua/admin/customorder/obrashchenie-klienta/2807436/edit/, the process was created from a missed call and an automation action once a minute Change the stage of the processes if there was a call with the client - the process switched to the stage Answered. Action Settings [file]13939[/file]
But as you can see in the process of the call that took place with the client, there is no [file]13940[/file] , why did the action switch the stage of the process?
On the example of the process https://crm.ohrana.ua/admin/customorder/obrashchenie-klienta/2807436/edit/, the process was created from a missed call and an automation action once a minute Change the stage of the processes if there was a call with the client - the process switched to the stage Answered. Action Settings But as you can see in the process of the call that took place with the client, there is no , why did the action switch the stage of the process?
Maria, thank you for your review. Please suggest why the process https://crm.ohrana.ua/admin/customorder/obrashchenie-klienta/2814506/edit/ did not switch to Answered? there is a call for 208 seconds, while the process remains at the starting stage hanging for 15 minutes and did not switch to answered
Maria OneBox production wrote: perhaps at the time of the action, there was no call yet
Didn't understand. The action is triggered every 10 minutes. We see the call at 12-12, if we assume that the action worked before that at 12-10, there is no call yet, but after that the action will work at 12-20 and there is already a call, why didn’t the process switch then ?
Maria
https://crm.ohrana.ua/admin/customorder/obrashchenie-klienta/2814614/edit/ same problem here
We are ready to finalize, but we just need to understand the functionality of the current actions, but I can’t understand how they work.
The call in the system was created at 13.21 (13.18 the start time of the call, so you see exactly this date of the event). It was processed at the current settings at 13.30. But when switching to the "Answered" status, this call will encounter an action that checks for the call "Check for a call to the client" The conditions that are specified there will not allow switching to this status (there was no call lasting more than 10 seconds in the last 5 minutes). Therefore, the action did not switch the stage Try changing the settings of this action so that it skips such calls.
