Improvement "Import orders from psauto.com.ua" stopped working.
Previously, we made improvements to import orders from the site psauto.com.ua. At the moment, the setting is enabled but all incoming orders to the site in OneBox are not transferred. Most likely the problem is that the site has moved to vps, please check if this is the reason, in which case - change the data.
when requesting from the box server to "https://psauto.com.ua/admintools/api****" we get the following error:
--2021-12-22 11:36:53-- https://psauto.com.ua/admintools/api****
Resolving psauto.com.ua (psauto.com.ua)... 193.169.188.42
Connecting to psauto.com.ua (psauto.com.ua)|193.169.188.42|:443... connected.
ERROR: cannot verify psauto.com.ua's certificate, issued by '/C=US/O=Let's Encrypt/CN=R3':
Unable to locally verify the issuer's authority.
To connect to psauto.com.ua insecurely, use `--no-check-certificate'.
Because of this, the integration does not work. Most likely you have a similar problem as in this topic https://1b.app/ru/forum/telephony/11259-ne-zatyagivaet-zvonki-v-sobitiya-logi-es...
22.12.2021, 11:46
Let's Encrypt is not currently the root of our certificate. Can you replace the saved certificate with the current one? If yes, how can we provide it to you?
22.12.2021, 12:01
A certificate from Let's Encrypt is installed on your site psauto.com.ua
22.12.2021, 12:29
