Hello,
the logic of the user settings items is not entirely clear.
There are putts in the user settings card
"Show popup on incoming call"
"Show popup on outgoing call"
but it is not clear how to remove the user from displaying incoming calls to a common line
and to another, so that these incoming to the common line are displayed ... tell me where it is written about it, and how to tune it up.
The user needs to see incoming outgoing only by the number that he has written in contacts ...
Hello, the logic of the user settings items is not entirely clear. There are putts in the user settings card "Show popup on incoming call" "Show popup on outgoing call" but it is not clear how to remove the user from displaying incoming calls to a common line and to another, so that these incoming to the common line are displayed ... tell me where it is written about it, and how to tune it up. The user needs to see incoming outgoing only by the number that he has written in contacts ...
you have in the settings specified "Numbers to which to show incoming calls first" and there are absolutely all the numbers .... I think you should remove it
Ustimenko Igor OneBox production Administrator OneBox CTO wrote: you have in the settings specified "Numbers to which to show incoming calls first" and there are absolutely all the numbers .... I think you should remove it
Please tell me in which section this setting is, I do not quite understand what is being said now ...
Ustimenko Igor
OneBox production
Administrator
go to system settings -> Onebox market -> Binotel -> select your integration on the right
Poltorak Sergey
Client wrote:
Ustimenko Igor
OneBox production
Administrator
