Automatically distribute employee business processes to other employees
- Configured action once per minute "Automatically distribute employees' business processes to other employees"
In which 4 statuses are selected, in which the order is not confirmed.
Go to the process https://rivcont.info/2336291/
The manager Nastya confirmed the order and Nastya was chosen as the responsible person at the confirmation stage
Next, we see that the responsible person was changed, as far as I understand by this action, but the process status no longer falls under the action settings
Why did it happen so ? look
Is this an isolated case?
This could happen when the cron took the process into processing and in parallel it was already changed.
08.09.2021, 16:52
OneBox production
Yes, only one case so far.
But, the problem should not be repeated, because the salary of managers depends on this parameter
13.09.2021, 11:33
I will not influence this, this can happen due to the parallelism of the processes.
14.09.2021, 14:43
OneBox production
Okay, if I repeat myself, I will send an example in order to understand exactly what the problem is
Maybe we'll come up with something
14.09.2021, 14:49
