Wrong data is inserted into document when creating document
Good afternoon!
We create an additional field of the business process with the "Contact Directory" data type, insert a variable into the document template to display data from this additional field, but after creating the document, instead of the data from the contact directory (first name, last name or company name), ID records from the directory get into it. box.cncele.com.ua
Thank you!
Igor, can you send a link to a document in which this problem is manifested?
18.02.2021, 18:40
18.02.2021, 20:39
corrected the display in the document for this type of additional field
logic will be updated on the server within the next few days
19.02.2021, 17:05
should work correctly, can you check?
22.02.2021, 10:33
Yes, now it's correct. Thank you!
22.02.2021, 18:52
