Problem with cell width and xls document opening
The template is implemented by a standard table in the editor and resizing cells
09.12.2020, 15:36
Hello. Why did you decide that html should be exported to xls with cells preserved? We do not have such functionality.
09.12.2020, 15:58
You have the functionality of creating a document and uploading it to xls. It is logical to assume that it will be unloaded in the same way as it looks. Is it a problem to keep the cell size when converting?
09.12.2020, 16:06
Bodyako Dmitry
Dmitry, be so kind as to communicate with customers more politely, and not to expose everyone as stupid idiots. The feeling that every appeal to you is a personal request beyond your authority.
Just replace this phrase "Why did you decide that html should be exported to xls with cells preserved?" to "Unfortunately" and the OneBox-enabled communication experience will be slightly better.
09.12.2020, 16:11
I don't consider asking "Why did you choose XXX" as impolite and making you look like a "stupid idiot". I think this is a common question.
09.12.2020, 16:40
Bodyako Dmitry
So, you have violated the concept of customer focus and politeness.
09.12.2020, 17:32
your right to draw any conclusions. Have a good day)
09.12.2020, 17:36
Farkhshatov Rodion
shine-bright.com.ua wrote:
Notification when opening any downloaded file generated from a template
What can I do to avoid this notification?
10.12.2020, 01:05
you need to play with libraries through which html is exported to xls and it is possible to change the current one to another one. Approximately 6 hours needed.
10.12.2020, 09:30
