Regular expressions
Good afternoon, please tell me where I can find documentation about this condition?
For example, can I take only the year from an additional field with the date type?
1. It is absolutely unclear where the screenshot came from, or from what specific action.
2. Judging by the name, the condition is met if the field selected on the left matches the regular expression. If the field with the date is selected on the left and you need to check that it contains a specific year, try writing something like 2025\- in this field. This way you will check that the field on the left contains the number 2025
20.03.2025, 15:52
1. Contact automation
2. Yes, the field with the date 2025-01-01 is selected, it turns out that I need to enter "2025\-"?
20.03.2025, 16:30
Yes, try it on two contacts. The first one where the year 2025 will be, the second one where the year 2024 will be and write the number one in some additional field of the contact
20.03.2025, 16:36
