fix the operation of the contact interface block "Contact in the directory" (changes are not saved when editing a field with type "Boolean" when the value changes from "1" to "0")
the "Contact in the directory" block is displayed in the contact interface
configured so that the job name and readiness fields can be edited
the guide includes test data for one contact https://spgr.1b.app/app/contact/8714/?tabid=8. When we go to the contact card and try to edit the data directly through the contact interface, we have a situation that when the value in the "readiness" field changes from "1" to "0" the data is not recorded
Please correct the error or indicate the reason for the incorrect operation of the system
https://www.loom.com/share/171b5a9aa01f4fd9a44493ec23707e67
Hello. Better use a different field type. For example, a drop-down list with yes/no options.
22.12.2022, 19:48
Перегіняк Олександр
Oneboxconsulting (интегратор)
Maria
OneBox production wrote:
Good day. It is best to use a different field type. For example, a drop-down list with yes/no options
it's not a question of how to get out of it, I know. It's just that you have a function and it doesn't work. It's an OS, not an MVP... Well, if you don't want to fix it, then ok... or rather "not ok", I'll work around it somehow, but other users, if they come across this, will consider it a bug .
26.12.2022, 16:47
Перегіняк Олександр
Maria
and one more moment... there is no drop-down list in the directory field
26.12.2022, 16:50
Перегіняк Олександр
I changed the field type to "text", made an entry in the directory for another contact, I try to make changes to the value of the directory field and I have the fact that nothing is saved. new contact I tested it in https://spgr.1b.app/app/contact/8884/?tabid=8
please fix this error. It seems that the problem here is not in the type of fields
03.01.2023, 18:44
