fix the operation of the contact interface block "Contact in the directory" (changes are not saved when editing record data)
the "Contact in the directory" block is displayed in the contact interface
configured so that the job name and availability fields can be edited
the reference contains test data for one contact https://spgr.1b.app/app/contact/8714/?tabid=8 . When going to the contact card and trying to edit data from directly through the contact interface, we have a situation that when clicking the check mark (save) the data is not recorded
Please correct the error or indicate the reason for the incorrect operation of the system
Good afternoon, you need to change the type of this field to Multilist of contacts, then go to each record and save the field with the contact to create the necessary link.
12.12.2022, 18:24
Перегіняк Олександр
Oneboxconsulting (интегратор)
Zamohilny Dmytro
helped, thanks!
13.12.2022, 13:03
