Hello!
In BP as a client, I specify jur. a person I cooperate within this BP with specific employees of the client. To do this, I created an additional field with a multi-list of contacts.
How to display processes in the contact card where the contact is not assigned by the client, but is indicated in such an additional field?
The Recent Client Processes block does not.
Hello! In BP as a client, I specify jur. a person I cooperate within this BP with specific employees of the client. To do this, I created an additional field with a multi-list of contacts. How to display processes in the contact card where the contact is not assigned by the client, but is indicated in such an additional field? The Recent Client Processes block does not.
Oleksandr, if you need to work with the company's employees, it is enough to assign the company to those employees' cards. And in the processes, choose those employees, not the company. Then display the list of processes in the employee cards, and in the company card also configure the display of all processes for all employees.
Ihor Susiak Integrator Integrator.com.ua wrote: Oleksandr, if you need to work with the company's employees, it is enough to assign the company to those employees' cards. And in the processes, choose those employees, not the company. Then display the list of processes in the employee cards, and in the company card also configure the display of all processes for all employees.
Due to the nature of my work, I need to communicate with several key people to conclude a contract. If I start the "Work with ice" PSU for only one employee or company, then this PSU "does not light up" in other contacts.
Ihor Susiak
Integrator
Alexander Lysenko wrote: Due to the nature of my work, I need to communicate with several key people to conclude a contract. If I start the "Work with ice" PSU for only one employee or company, then this PSU "does not light up" in other contacts.
everything is right, as it should be. if you need to mark several contacts in one process - display the Contacts tab or tab, where you can add as many as you need. for example screenshot:
everything is right, as it should be. if you need to mark several contacts in one process - display the Contacts tab or tab, where you can add as many as you need. for example screenshot: [file]13128[/file]
Are all contacts from the same company? If so, you enter the processes in the company card. If not, then by default such a system works only for a specific contact. Accordingly, generate as many leads as contacts. They can be linked through the parent process.
Ihor Susiak Integrator Integrator.com.ua wrote: If so, you enter the processes in the company card.
Not quite understood what you mean.
Ihor Susiak
Integrator
for example, here is the contact in which the company is selected go to the company map, display the processes block and see in the results the processes for the company's employees, including did you need it?
for example, here is the contact in which the company [file]13142[/file] is selected
go to the company map, display the processes block and see in the results the processes for the company's employees, including [file]13143[/file]
did you need it?
Ihor Susiak Integrator Integrator.com.ua wrote: did you need it?
Not at all. I have implemented this for a long time. The idea was as follows: A large enterprise. We are working on a deal with several of his employees. If I specify a company as a client, none of the employees have this process displayed on the card. If I specify one of the employees as the client, then the BP is displayed exclusively in this person's card and in the company's card. I want to indicate in the BP all those involved and for all those involved to have this BP displayed in the card. Somehow.
Ihor Susiak
Integrator
did you need it?
Somehow.
Alexander Lysenko wrote: If I specify a company as a client, none of the employees have this process displayed on the card.
do you display the processes in the contact card with the Recent contact processes block? screen1 then you can put a checkmark and then it will show processes by company, and you may also need two other checkmarks (screen2)
do you display the processes in the contact card with the Recent contact processes block? [file]13153[/file] screen1
then you can put a checkmark and then it will show processes by company, and you may also need two other checkmarks [file]13154[/file] (screen2)
