how to disable slash / in user.user_company field
Hello, please tell me how to forbid entering a slash / in the user.user_company field, it is desirable that only uppercase and lowercase letters and numbers can be entered in the name ... tell me how to configure this?
enable reverification on third-party symbols: https://take.ms/T4TBa
your_box/admin/shop/settings/unique/
30.09.2021, 12:08
Yarina
thanks - didn't help. Activated.
I edit user.user_company and, as before, a slash is inserted and saved...
What other options are there?
30.09.2021, 12:24
reconciliation work only for a new contact
30.09.2021, 13:32
having checked, when the checkbox is enabled, it is not allowed to enter any symbols in the Name and name of the contact
and you can ask yourself about the name of the company, and there you can either be a symbol, for example, Mozilla firefox will position itself as "Moz://a" - apparently, it’s not suitable for you - just change it manually, or more (not a fact that retailers wait to add some exchange, there is no way for companies)
30.09.2021, 13:40
Please note that I wrote originally - I'm talking about the user.user_company field
Company names also cannot contain special characters...
30.09.2021, 15:34
OneBox Corp - Інтегратор
Poltorak Sergey
And what about quotes, are they third-party characters? But for some reason, 90 percent of companies are filled with quotation marks. In general, such a check turns out to be not logical, especially since who in the common sense introduces a slash into the name if it is not the name of the company?
30.09.2021, 21:00
well, in fact they make a slash, but it is necessary that there is no possibility - therefore I am looking for a tool how to implement it.
01.10.2021, 09:31
Poltorak Sergey
in the automation for contacts, set the action Check the field by template there, set up the template on a regular expression and specify the company name field
and you will get an error if there is a symbol you specified
03.10.2021, 20:37
