The setting "Hide full name fields" does not work for additionally created contact types
In Onebox OS, we are trying to set up additional types of contacts https://oxrana.crm-onebox.com/app/contact/setting/typesex/ .
We need to do extra. type , which will be a kind of copy of the "Company" type, that is, in it we will not fill in the full name, but only the name of the company.
https://oxrana.crm-onebox.com/app/contact/setting/typesex/9/ - in the type settings enabled the setting "Hide full name fields"
But when creating a contact, the system still asks to enter the name of the contact
Why don't you just want to create all companies as typesex=company?
If the point is to separate the interface, then you can divide the companies into groups and configure the interface relative to them.
01.09.2021, 14:50
OneBox production
Accidentally marked the answer as correct.
We do not want to use contact groups yet. I would like to select only the required type and immediately get the desired interface, without filling in additional fields.
01.09.2021, 20:47
I see 3 solutions to this issue:
1. the above regarding groups - without any modifications
2. make sure that when updating a contact, the check for the full name only works if the contact type is specified without a check mark "Hide full name" - this is a 2-hour revision
3. refactor the entire system instead of checking for typesex=company - so that the "Hide full name" checkbox is checked - and it is considered a company - it's about 30 hours and I can't say which logics (for example, actions) will be drastically violated
02.09.2021, 11:04
