Contact automation does not work when automating once an hour. [file]9502[/file]
The action once an hour updates the group to the client, but the automation for contacts does not work at this time [file]9503[/file]
Contact automation does not work when automating once an hour. The action once an hour updates the group to the client, but the automation for contacts does not work at this time
This action simply adds the contact to the group, without triggering automations. If you need it - it can be modified by setting it into action in 1 hour.
And if you make for all actions "Create a group of contacts" a tick "start automation of contacts"? I think this will be useful to many.
And if you make for all actions "Create a group of contacts" a tick "start automation of contacts"? [file]9598[/file]
Granovsky Mikhail wrote: And if you make for all actions "Create a group of contacts" a tick "start automation of contacts"? I think this will be useful to many.
I rated it above and for the indicated action
Please send me an invoice for revision. Let's start implementing.
Can you please send an invoice?
Granovsky Mikhail wrote: Can you please send an invoice?
You were sent an invoice to your mail (from your account) on 20.08 Please check your email (including spam)
Please duplicate, there is no account anywhere :(
added the setting "Start automation for contacts (save) after adding to a group" to the action "Create a group of contacts: clients for whom no business processes have been registered for X days" (and other similar ones configured in your automation)
