Previously, the BZ had a function in which it was possible to specify for which role / roles this article was written. Also, in the contact interface there is a block "Articles by role", in which only articles for this role were displayed.
Now all articles are displayed in this block, you can limit it only by category.
Client https://aquadevice.crm-onebox.com used this functionality. Is it possible to return it?
Previously, the BZ had a function in which it was possible to specify for which role / roles this article was written. Also, in the contact interface there is a block "Articles by role", in which only articles for this role were displayed. Now all articles are displayed in this block, you can limit it only by category. Client https://aquadevice.crm-onebox.com used this functionality. Is it possible to return it?
It doesn't work with "Required for" https://i.imgur.com/d7FTQ0H.png - https://i.imgur.com/Mvy6Rfj.png
Article https://aquadevice.crm-onebox.com/app/knowledgebase/edit/493/
Contact https://aquadevice.crm-onebox.com/app/contact/1866/
Maksym Vadimovych Tyndyk OneBox production wrote: Then this functionality was canceled, and in the block there is an opportunity to display certain categories of articles.
In this case, in order to display different BZ articles for different roles, it is necessary to configure a separate contact interface for each role, and the name of the block does not correspond to its essence. Is it possible to restore the display of articles by role?
