Loading from a file with a vendor ID does not create dummy products
Good afternoon, when loading goods through the import block by the supplier code, only the found goods are added to the process, although earlier if the goods were not found, there were empty lines and it was easy to determine which goods were not. Tell me how to fix this situation?
The example below, there are 36 products in the file, and if you make an import, then 35 products are added to the table.
In this case, it is still possible to find 1 product, but when we load 200+ products and we need to find several among them, it is very problematic.
I repeat, a little over a week ago an empty line was created in place of a product not found.
Process: https://owwa.crm-onebox.com/admin/customorder/order/12797/edit/
The download file is attached.
Can you point out on which line from the file exactly the problem?
Is the position in the file accidentally duplicated?
20.04.2021, 18:54
Андрій
CEO, owwa.com.ua
The position is not duplicated, just before you tested the logistician created this position for posting and you did not find an error - we detached the supplier code from the product to recreate the situation.
If you repeat adding products, 35 out of 36 will be added.
Missing position on line 16 with code 15386.
20.04.2021, 20:23
https://owwa.crm-onebox.com/admin/customorder/order/12797/edit/ - added item with serial number #85 Adjusted leg NL 05/100-108 G2 d-30mm rolled Chrome DS StandardLine - fictitious product
Does it seem to work as it should?
22.04.2021, 16:05
Андрій
CEO, owwa.com.ua
Maxim, yes, today it is already working - thanks!
22.04.2021, 18:26
