Filter field "Suppliers" does not work
Also, products are no longer filtered by availability.
Screenshots below
I am also attaching screenshots that suppliers are not filtered instead of selecting a supplier, the field "All suppliers" appeared
[file]4143[/file]
[file]4144[/file]
[file]4145[/file]
[file]4146[/file]
Filter field "Suppliers" does not work Also, products are no longer filtered by availability. Screenshots below I am also attaching screenshots that suppliers are not filtered instead of selecting a supplier, the field "All suppliers" appeared
Availability filtering works, if the checkbox is checked, goods in stock will be visible if this checkbox is unchecked, goods without a checkmark will be available
Availability filtering works, if the checkbox is checked, goods in stock will be visible [file]4148[/file] if this checkbox is unchecked, goods without a checkmark will be available [file]4149[/file]
