Good afternoon. If you upload a file today, and tomorrow upload a file where some product is not available, it will automatically be marked as Out of stock by the supplier, due to the fact that it was not in the new price list. In order to disable this logic, you need to enable the system setting "Do not specify Out of stock for products that are not in the price list" /admin/shop/settings/recalculate-price/
11.12.2020, 18:54
the question is not what is in the file, but what is not? the question is that the product that is in the price list with the status "in stock" after loading into the program is displayed as "out of stock"
14.12.2020, 13:12
the fact of the matter is that only when loading it shows that there is availability, but in fact after loading the product does not go into the status "in stock"
15.12.2020, 11:50
every day I load the price list and every day most of the goods are "in stock" when loading, but in fact the status in the database is "out of stock"
example on one product:
yesterday - Xerox 6020 loading "in stock" - Old show "out of stock"
today - Xerox 6020 when loading "in stock" - Old Show "out of stock"
tomorrow - Xerox 6020 when loading "in stock" - Old show "out of stock"
and so day after day, the product does not fall into the status of "in stock"
15.12.2020, 11:57
This availability is the availability of goods at the supplier. It is not directly related to the availability of the product. In order for the availability to be indicated in the product card based on the data of suppliers, it is necessary to recalculate prices.
15.12.2020, 18:18
how many more times do you need to explain that the problem is in the program in order to get adequate help and solve the problem? where the computer is turned on, I know, and how to download the supplier's price list and what to do next with them, everything is also known, and it worked (4 years). The question is why the information about the availability is not updated and the product that is constantly in stock from the supplier does not go to advertising?
16.12.2020, 09:27
Please provide a link to your system. Perhaps you also have an action once per hour / day that sets the presence of goods of the ERC supplier to 0
16.12.2020, 18:00
remove an action from the list. What is the problem? You set an action that changes the availability of goods and then write that the action of changing the availability of goods should not work. Well, remove it, it will not work and touch the goods of this supplier.
developers usually do not communicate directly with clients in the normal course. If you need it, we can discuss the conditions and cost of such requests.
18.12.2020, 11:06
Dmitry, please understand - the action does not pull the availability of the ERC provider. Not all positions go through the API - the supplier often updates the positions and you have to load them manually. Tell me how to do it right.
12.01.2021, 12:36
"Not all positions go through the API - the supplier often updates the positions and you have to load them manually." - for which it was paid as a revision, (Automatic download + manual) and everything worked.
Now only manual works. Automatic download doesn't work at all! We didn't manually load anything for several days and nothing has changed. The presence as it was all in the red remained.
13.01.2021, 09:22
Andrey, we have several options for solving the problem:
1. You go to a meeting with me, include actions, give a link to a product that should definitely be updated by this action - I see what is wrong with the action and solve your issue.
2. You keep writing comments like "nothing works, you don't solve anything" and so on and no one really gives you any solution.
ps specifically from me, as far as I can see, you received answers in this topic within a short period of time, for the first time I hear about some 2 months of waiting.
13.01.2021, 18:07
erc changed its api, you had an old version of box that didn't support the new erc api. Added to support - launched the import action - the results of the import will be in half an hour or an hour
19.01.2021, 16:59
Perhaps it was on your box that there were no changes yet, as far as I can see, it has not been updated for a long time. Updated your system, you can check tomorrow at the outlet, is everything okay now?
21.01.2021, 10:27
The previous message was written by mistake, it was intended for a different topic.
On this topic. You have selected categories in the action settings, a category in ERC in the specified product
http://ob.eurocopy.ua/admin/shop/products/77748/supplier/ "Laser monochrome printers", if categories and the name of the product category are selected in the action settings in erc does not match the name of the selected categories - the product is not imported into the system. In order for this category to start getting into the system, you need to create the "Monochrome laser printers" category and select it in the action settings. You can also change the name in Russian of one of the current categories.
21.01.2021, 10:46
Not a very rational solution, since initially everything was built on this so that the name of the categories would be compared with the supplier "Monochrome laser printers" from the supplier = "Monochrome laser printers" - in the program. And this, too, was all one of the improvements when the program was launched. Plus, since the time everyone set up the name of the categories, neither we nor the supplier has changed. And most importantly, from the first day there was no task to become attached to categories. The main link worked on the article numbers of the goods, since this is one of the most accurate determinants of the goods.
21.01.2021, 13:49
can you provide the id of the task in which this was done?
If the main link is as you say, then it makes no sense to select any categories in the action. But you have them selected, which means it was done on purpose for some reason.
21.01.2021, 13:58
1) Bodyako Dmitry
"If the main link is as you say, then it makes no sense to select any categories in the action. But you have them selected, so this was done on purpose for some reason"
It makes sense in action, since the supplier has a lot of such categories, and at the time of launch there was a question of rationality to load everything (and there are about 35,000 positions of various goods), or still select only the categories of interest to us and load only about 4 into the program 000 positions for analysis and processing. That is why certain categories are selected there.
It is not possible to change category names as they are associated with other advertising resources.
2) Regarding "provide the task id" - this was all done 3 or 4 years ago and such data was not saved (did not see the need for this)
21.01.2021, 14:58
Andrey, I described above why your product is not included in the list of updated ones. For this to happen, you need to create a category called Monochrome Laser Printers and select it in the import settings. To prevent the categories from being updated for the products themselves, you need to check the box "Do not update categories for products and do not add new ones" in the action settings. Unfortunately, I don’t see any other logic about the improvement of which you write on the current version of the product.
26.01.2021, 16:43
Commentary is available in ru and not yet translated to the current language.
27.01.2021, 09:48
Will there be other options? there was a knock on the wheel ..... the headlight was rubbed ..... what else can we do to make the problem remain unsolvable?
27.01.2021, 09:54
