How to make the bot check whether the user is registered on the site or not
I am creating a tg-bot, I need people to follow the link that the bot gives and register so that the bot then provides the necessary content
Ярина
Good day. it can be programmed with a process and automatic stage switching. You will not need an app, only a created bot.
we can show examples of processes.
06.07.2023, 08:29
It is necessary somehow for the user in the box after registration to write a value to some additional field, in order to then check it and display some buttons of the bot (with content) or not. To do this, you need the site to transfer the API information to the user after registration, or vice versa, do all the registration inside the bot, and simply transfer the necessary information to the site via API
06.07.2023, 09:05
