Cron action required once per hour
Which would check all payments that do not yet have a payment category + the description field is filled in (comment to payment)
And then it would be possible to customize the pregs (example)
%Transfer%+%Yaroslav% -> means move to payment category "Accounts with suppliers"
That is, to be able to specify 1 or more words (if there are several, then they must meet together in a comment to the payment) and if it finds a payment that does not yet have a category and there are these words in the comment, then transfer them to a specific category.
and such conditions should be added an unlimited number, that is, there should be a certain "plus" that would allow you to add more and more options for distributing payments by category.
How many hours is this?
Cron action required once per hour Which would check all payments that do not yet have a payment category + the description field is filled in (comment to payment) And then it would be possible to customize the pregs (example) %Transfer%+%Yaroslav% -> means move to payment category "Accounts with suppliers" That is, to be able to specify 1 or more words (if there are several, then they must meet together in a comment to the payment) and if it finds a payment that does not yet have a category and there are these words in the comment, then transfer them to a specific category. and such conditions should be added an unlimited number, that is, there should be a certain "plus" that would allow you to add more and more options for distributing payments by category. How many hours is this?
