Есть вопросы по настройке компонента? Вы всегда можете создать топик на нашем форуме и там описать интересующий вопрос! Наши партнеры с радостью вам ответят.
Создать топик
Hello, please tell me what exactly is meant by the ID for writing to this field [file]3402[/file] is the bank account number or some other ID and what else do you need to connect for integration besides this action
Hello, please tell me what exactly is meant by the ID for writing to this field is the bank account number or some other ID and what else do you need to connect for integration besides this action
Bodyako Dmitry dev wrote: When registering and linking the card to liqpay, you were given 2 values: id and private key . This is one of them
these 2 are given in liqpay i.e. once again you need to write the public key or all the same as in the comment https://crm-onebox.com/user/200/ you need create account/wallet ID in OneBox ?
Bodyako Dmitry
these 2 are given in liqpay [file]3418[/file] i.e. once again you need to write the public key [file]3419[/file] or all the same as in the comment https://crm-onebox.com/user/200/ you need create account/wallet ID in OneBox ?
OneBox account/wallet ID to which payments will be made
i.e. for example wallet put 1 here ?
Administrator wrote:
antip wrote:
some other ID
i.e. for example wallet [file]3420[/file]
put 1 here ? [file]3421[/file]
Bodyako Dmitry dev wrote: somewhere in liqpay personal account you should still have a field with the account/card ID
like this is the same public key the account does not have any other id
Bodyako Dmitry
like this [file]3422[/file] is the same public key
Bodyako Dmitry dev wrote: Sorry, I made a mistake - this is not the id from liqpay, this is the id of the account in the box to which you need to send the received payments
Bodyako Dmitry
So ?
https://crm-onebox.com/en/ajax/download/3420/
https://crm-onebox.com/en/ajax/download/3421/
everything went through with liqPay please tell me why the BP does not pull up the information on the payment
here is an order with liqPay payment from the outlet https://box.optodess.com.ua/admin/customorder/order/807674/edit/
BP fields are empty [file]3491[/file]
integration set up according to the dialog above https://box.optodess.com.ua/admin/shop/integrations/liqpay-integration-5/control/
[file]3492[/file]
everything went through with liqPay [file]3493[/file]
And what is the connection between importing an order from Rozetka and integrating payments from the site?
antip wrote:
BP fields are empty
But that is, if the order is from the outlet, then liqpay cannot be tracked on it?
antip wrote:
BP fields are empty
antip wrote: But that is, if the order is from the outlet, then liqpay cannot be tracked on it?
No, this is not included in the integration. If payments come to Privat, import them into the system with an automatic action and link them to processes. Integration of liqpay is needed in most cases to form a form of payment in an online store / personal account and then accept payments after callback requests from liqpay
please tell me what is the action
I did not find such an action, can you please link to it
connect the integration in the Privat24 market, after which the above action will be available to you
