Hello, as far as I can see, the course does not arrive directly in the response
https://prnt.sc/v4dg87 , perhaps the amount in hryvnia is in the operationAmount field, but there is no description, i.e. this is pure guesswork. Solution 2:
1. If the amount in operationAmount is in hryvnias, then you can transfer the amount in the base currency, or calculate at what rate the monobank calculated it and set this rate strictly in the payment. 2h
2. Take the exchange rate from monobank and make a payment at this rate. Those. you will need to make a separate request to the api to get the rates and record the rate in the payment rate. It also takes 2 hours
the first option is a priority, but in order to understand - some kind of payment in foreign currency is needed to check my assumption
