The integration with the new MONO account does not work
02.12.2024, 13:28
Good day Maybe the wrong token is specified in the connected integration settings
02.12.2024, 14:10
Maria
I checked again, the token is valid. I wrote to support to clarify how to generate it correctly. Everything is done as they say
02.12.2024, 16:50
From the official documentation of the monobank https://prnt.sc/MoNcLQY8-VaS
You need to go to the link and log in https://api.monobank.ua/
You will then see an available token that can be used
02.12.2024, 17:16
The same, faced this problem recently - you just got into a period when Mono does not hold up and falls, so your token is lost. Try again later
02.12.2024, 17:45
Thank you.
Try a new creature?
02.12.2024, 19:42
Maria
Thanks a lot, it worked with this token
05.12.2024, 22:22
