Create a link for payment in WAYFORPAY
Congratulations! Maybe you can help with such a problem. There is an order amount and there are obligations for it. When you create a payment link and if some payment is already connected, the payment link does not take into account what has already been paid and creates a payment for the total amount of the process. How can it be fixed?
Good evening
If you use payment amount = order amount in the settings, then the action will take the price, quantity and name for each product of the process to create (this information is visible to the client when clicking on the link).
If you use an amount from an additional field, then exactly that amount will be taken from the field and a link will be created with the text 'Payment' (or a description of the payment from the action setting) instead of the product name
You can always use an additional field to calculate the required payment amount
18.11.2024, 18:36
Volokhovich Evgeniy
Адміністратор
Maria
OneBox production wrote:
Good evening
If you use an amount from an additional field, that amount will be taken from the field and a link will be created with the text 'Payment' (or a description of the payment from the action setting) instead of the product name
Thanks for the answer! Tell me one more question, can we create links with the amount at will? I ask because there is a partial payment for the order
21.11.2024, 00:33
