Help with connection to monobank
can you throw off the screen of the adjustment of diї in automation?
The most common problem is that the account holder selected in the "User from which payments will be created" field does not have access rights to the account that is selected in the field "Account to which payments will be credited" (it is more convenient to select the account holder there with equal access to Admin)
26.10.2022, 21:06
Sergiy good evening
1) back off the API key here https://api.monobank.ua/
2) install addon and set up integration with Monobank here /app/monobank/
3) create a gamble, split Account payments /app/payments/settings/account/
4) add and complete the "Monobank Statement" message on the fine crown /app/automatization/minute/edit/ by selecting the required integration card, card, valid (required rights) and account
If everything is successfully completed, the actual payments will be shown in /app/payments/. If you don't know how to automate them - put a new topic on the forum.
26.10.2022, 21:14
