If you mean the setting "When adding a payment to a client, change the amount of the invoiced payment for this request" - then it only applies to incoming payments from the client (you have an outgoing payment in progress). If you need to finalize the reduction of outgoing payments - such a revision will take 2 hours. Bill?
Tyndyk Maxim Vadimovich OneBox production wrote: If you mean the setting "When adding a payment to a client, change the amount of the invoiced payment for this request" - then it only applies to incoming payments from the client (you have an outgoing payment in progress). If you need to finalize the reduction of outgoing payments - such a revision will take 2 hours. Bill?
So
So
Tyndyk Maxim Vadimovich OneBox production wrote: Renamed and changed the logic of the above setting - now payments are reduced in both directions.
No change
No change
[file]16220[/file]
You have here a renamed setting "When adding a payment to the process, change the amount of the charged payment for the process" It sounded different before.
Tyndyk Maxim Vadimovich OneBox production wrote: You have here a renamed setting "When adding a payment to the process, change the amount of the charged payment for the process" It sounded different before.
What is the difference?
If you read carefully - now it does not appear that it should be "payment by client" - that is, it works in both directions of payments.
Why don’t the payment points change on the real application https://smile.1b.app/82/?
Please check again. As far as I can see, everything works, the outgoing payment decreases.
Dyakuyu! Now it's working.
