System Version - OS
You need to connect several wayforapy integrations - now you can only 1
How many hours is this?
You also need to immediately evaluate the action to create a link to pay for wayforpay - so that you can choose which integration to make a link with - how many hours?
System Version - OS You need to connect several wayforapy integrations - now you can only 1 How many hours is this? You also need to immediately evaluate the action to create a link to pay for wayforpay - so that you can choose which integration to make a link with - how many hours?
Tyndyk Maxim Vadimovich OneBox production wrote: Do you need it only for action?
Yes, you need to have several integrations in order to generate payment links from different sites
Well, then it's easier to refine the link creation action - the ability to specify merchantAccount and merchantSecretKey directly in the action - and then you can add several actions with the necessary accesses at different stages. This revision will take 1 hour.
Tyndyk Maxim Vadimovich OneBox production wrote: Well, then it's easier to refine the link creation action - the ability to specify merchantAccount and merchantSecretKey directly in the action - and then you can add several actions with the necessary accesses at different stages. This revision will take 1 hour.
Ok, please send me an invoice.
