LiqPay payment not confirmed
Есть необходимость работы с LiqPay в системе?
У нас есть готовый компонент для работы! Посмотреть компонент
Good afternoon, LiqPay payments have ceased to be confirmed today.
An example of the process where you need to confirm the payment: https://owwa.crm-onebox.com/admin/customorder/order/155300/edit/
For payment, a procedure is set up with the button "Confirm LiqPay" - you can run it for the test.
We do not change the payment status after clicking.
Procedure setup link: https://owwa.crm-onebox.com/admin/shop/workflow/23/procedure/109/?status=0
you hid the procedure
is the question relevant?
19.01.2022, 10:12
Андрій
CEO, owwa.com.ua
We solved the problem, somehow removed the integration - set it up again and everything worked out. Thank you!
19.01.2022, 14:14
