The exchange rate update does not work in the process for the current
Good afternoon. I'm trying to update the exchange rate in the process with the current one, I placed it in the procedure when I click
https://crm.ohrana.ua/admin/shop/workflow/16/procedure/824/?status=0
Next, I change the exchange rate of the Shat Dollar from 200 to 400, but the exchange rate does not change in the process
The process for checking https://crm.ohrana.ua/admin/customorder/zakaz-klienta/2516515/edit/ at the time of the creation of the process, the rate is 200, now it is 400, but I don’t see any changes in the process
please check. Thanks
Based on the description of the action "When you go to the stage, the process currency rate will be updated as of the selected moment." - at the moment, the UAH currency is set in the process - in fact, the exchange rate has not changed there.
If you change the currency to another in the process (for example, as indicated in the screenshot "Dollar Shat") - it will update the rate for this currency.
19.11.2021, 14:44
Maxim, maybe there is another action. I need to click on the button so that the rates that are displayed in the block of the process change to the current exchange rates
19.11.2021, 17:04
There is a first commit action "Fix currency rates in progress"
As an option - I can offer a revision in 1 hour - add the "Update process currency rates" setting to this action.
22.11.2021, 11:48
